XXSNOTRODXX
Are you doing this on dry pavement? If you are, the binding could your differential locking up and no letting wheels spin at different speeds. Try to find a field or gravel area to test it out.
***Edit, Sorry did you see your last post.
I have not tried in gravel. But the fact is, even on dry pavement these problems did not exist prior to the leveling kit.
I know 4x4 is not meant for dry pavement. But I tested it prior to the level install specifically for comparison sake and in 4x4 on dry pavement there was no vibration under acceleration or anywhere up to the 45 mph I took it too. And no binding during a turn ( maybe slight binding at full lock which you can expect out of any 4x4.....but post level it didn't take much of a turn at all before severe binding occurred).
Add to that now this new issue the alignment shopping has told be where it pulls left under acceleration. Quickly feeling disappointment and regret on this bilstein install.
