Bravo1
I notice with Superlift's 4 inch lift they use a spacer that mounts to the Bilstein 5100 at the top before reinstallation in a 2013 Ram 1500.I currently have 5100 up front. The shock setting is at the number 4 ring position one less than the max position,and for the rear axle I have a SuperLift rear 2 inch spring.My question is can I install a ReadyLift 1 7/8 inch spacer on top of the Bilstein 5100 in the frt end. The truck measurements are 38 1/2 up frt and the rear is at a 40 1/2 a 2 inch difference.So the frt has to come up.
