Blower motor squeak
Discussion in 'Interior' started by tcazes, Jan 9, 2017.
  1. tcazes
    tcazes Senior Member
    194
    47
    Dec 7, 2016
    Ram Year:
    Engine:
    5.7L
    My 2013 Laramie long horn actually blower motor has started to lightly squeak. Has anyone had to pull their dash apart to service this yet? It drives me insane.
  2. smiley3303
    smiley3303 Super Moderator Staff Member
    31
    5,691
    1,445
    Apr 18, 2011
    Minot, ND
    Ram Year:
    2009 Ram 1500 Laramie Crew 4WD
    Engine:
    It is really easy. Remove the glove box door by opening and swinging all the way down it will come off look at hinges. Then just look under there it is held up by 3 screws and a couple wire harnesses plug into it if you have dual zone climate control. Probably less than 10 minute job. I just replaced mine with a salvaged one out of a 13. You can find one at www.car-part.com just make sure you choose the right option DZ climate or not will make a difference. Squeak gone!
    Ram Man, tcazes and 02blkram47 like this.
  3. 02blkram47
    02blkram47 Senior Member
    1,081
    68
    Oct 19, 2011
    Lebanon, NH
    Ram Year:
    2011 Longhorn Crew Cab
    Engine:
    I'm going to check this out. My squeak is awful
    Sent from my XT1635-01 using Tapatalk
    smiley3303 likes this.
  4. Broyd
    Broyd Senior Member
    111
    45
    May 9, 2016
    Rossland BC Canada
    Ram Year:
    Engine:
    We seem to live in a throw away society. The squeak is caused because the motor bushings are dry; it has run out of oil. Other than this small problem, the motor is normally fine. Before I ever replace a motor for dry bushings, (or worn out motor brushes) I'll look for a way to oil them! Although this hasn't happened to my RAM blower motor yet, I've oiled dozens of small brush and brushless motors in the past. Sometimes this requires drilling out rivets and replacing them with screws but no big deal. I cringe :).
    Hootbro likes this.
  5. Hootbro
    Hootbro Senior Member
    2,015
    969
    Jul 31, 2015
    Ram Year:
    2015 2500
    Engine:
    Seems to be a somewhat common problem. Mine has started to chirp on the lower speed settings with the recent cold weather off and on but is not enough consistency for me to waste my time trying to get it warrantied out yet.
  6. tcazes
    194
    47
    Dec 7, 2016
    Ram Year:
    Engine:
    5.7L
    Wow that's a relief! I'll pull mine out and try to oil it later. I never just chunk them. Always oil em up first lol
  7. Ram Man
    Ram Man Senior Member
    473
    94
    Jul 1, 2010
    FL
    Ram Year:
    2013 Sport
    Engine:
    Low speed + cold(ish) temps make my blower squeak too... If anyone has success oiling it please post and update.
  8. tnmotown
    tnmotown Junior Member
    24
    Oct 13, 2016
    Ram Year:
    Engine:
    Mine has a small chirp type of sound also. Maybe I'll look into oiling it up like mentioned. It hasn't been that bad yet where it really annoys me lol!
  9. smiley3303
    31
    5,691
    1,445
    Apr 18, 2011
    Minot, ND
    Ram Year:
    Engine:
    I kept my original one to see if there was a way to fix. Looking at it it does not look very fixable but it I can revive it I would happy to do so! The throw away society comes from the fact the parts often can't be serviced anymore. I like salvage yards to help defray a little waste when I can.
    tcazes likes this.
  10. BBRAM2500
    BBRAM2500 Senior Member
    38
    203
    62
    Jan 3, 2017
    stony plain Alberta
    Ram Year:
    Engine:
    6.7
    My 2014 from day one squeeked at low speed i hated it
Share This Page
