Blower problem
Discussion in 'General Discussions' started by wiram, Jan 5, 2017.
  1. wiram
    wiram Senior Member
    25
    194
    20
    May 28, 2013
    Sparta, wisconsin
    Ram Year:
    2006, 1995
    Engine:
    hemi 5.7, 5.2 318
    2006 ram 1500 5.7 only blows air on highest setting could the switch be going out or something else causing the problem?
    Sent from my SM-G900R4 using Tapatalk
  2. 82Crew
    82Crew Senior Member
    220
    136
    Oct 10, 2014
    North of St. Louis
    Ram Year:
    1982, 2010
    Engine:
    318 Magnum, 6.7 Cummins
    More than likely it is the blower resistor. High speed bypasses the resistor.
  3. wiram
    wiram Senior Member
    25
    194
    20
    May 28, 2013
    Sparta, wisconsin
    Ram Year:
    2006, 1995
    Engine:
    hemi 5.7, 5.2 318
    Thank you that's what my friend said just wanted a few opinions before I do anything
  4. wiggy999
    wiggy999 Senior Member
    89
    103
    57
    Jan 13, 2017
    Ottawa, On. Canada
    Ram Year:
    2006
    Engine:
    4.7
    18$ part, 5 minute fix.
  5. wiram
    wiram Senior Member
    25
    194
    20
    May 28, 2013
    Sparta, wisconsin
    Ram Year:
    2006, 1995
    Engine:
    hemi 5.7, 5.2 318
    So I replaced it tonight the old one was cracked. Still have the same issue any other ideas?
  6. smiley
    smiley Super Moderator Staff Member
    31
    5,849
    1,574
    Apr 18, 2011
    Minot, ND
    Ram Year:
    2009 Ram 1500 Laramie Crew 4WD
    Engine:
    Had a car do it once and it was the actual control unit.
  7. RonJon '06
    RonJon '06 Senior Member
    3,306
    1,050
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    Have you checked the recirc door? The hinges tend to break and the door can block the passage cutting off the airflow. This happened on my '06 a few years ago.
  8. wiram
    wiram Senior Member
    25
    194
    20
    May 28, 2013
    Sparta, wisconsin
    Ram Year:
    2006, 1995
    Engine:
    hemi 5.7, 5.2 318
    It blows like normal only on the highest setting.
  9. Langer5192
    Langer5192 Junior Member
    Dec 22, 2016
    Ram Year:
    Engine:
    5.9
    Might help, might not. I was having issues with the control of my blower motor. I found a wiring harness under steering column and when i shook/moved it, the blower motor would start propperly working, i heard these get loose corroded all the time
Share This Page
