First post here, I have been reading quite a bit about the various options that are available for what I'm looking to do. Right now I have a 2014 Black express crew cab with stock rims and tires (tires are 10.8" wide, 33" diameter). I put fender flares on it and am looking to 1) space out the wheels to compensate for the flares and 2) add a body level/lift to it. I was looking to space the wheels out 2", but I was going to do this by adding 325/60/20 grapplers (12.8" wide, 35.4" diameter) on it and then add a 1" spacer which would get it back to the same as the stock clearance on the inside wheel well. I was also looking to add a 3" front / 2" rear lift/level on it to accommodate bigger tires, this would leave a .5" rake which is fine. Just looking for advice on what would be best for what I'm looking for. I put this in the lift section because the lift will determine what spacers I end up with. Thanks for all who help!
