misuracaf10
- Aug 3, 2014
- 454
- 142
- 2014
- 5.7
Hello everyone,
Been having a bit of an issue with brakes. At 60,000 miles I got them squeaking pretty hard so I replaced them at a local shop and figured that as routine maintenance, I’m not sure the brand, but they have a 2 year 24000 mile warranty which enticed me to go that route. I saved a few bucks that way and wasn’t sure what the dealer offered in terms of brakes and warranty.
1,000 miles in the front left started grinding on the outside of the rotor. They chalked it up to a manufacture pad defect. I got both pads and rotors replaced no issues.
Second time around, left front brake is grinding again after 1,000 miles... but this time it’s the inside of the rotor, outside looks perfect and the inside has the round wear rings etched in there essentially. And they grind from about 20mph to 0 with medium pressure on them and I have no idea why.
I’m wondering if anyone has problems with aftermarket pads and rotors? Or does this truck only do well with OEM rotors and pads? What else could be causing this problem? I had 0 brake issues since the truck was new, and they are fine right after they are replaced until about 1000 miles into it. Any ideas on what this could be? I’m taking it in tomorrow to see what they say. I might ask for a refund and try to just go to my dodge dealer to get them fixed. Unless they have access to OEM stuff which I bet they do
