Brake pads...wagner or powerstop??
Fritzzz
Vancouver
Hey folks...I have a 2018 sport with 41k km on it and its about time to replace the pads...I used oem my whole life and decided to try something dif....looks like wagner and powerstop are pretty good...and both allegedly don't release too much brake dust..so...which one should I go? Here in Canada wagner looks considerably cheaper than powerstop
Thanks
daveray9
+1 on wagner OEX
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
5k miles into powerstop pads n rotors. All positives from me.
Just make sure to bleed the ABS. I didnt till about 2 weeks after the change and it was a night and day difference. Used alphaobd and i almost pooped my pants when it yanked my pedal from under my foot
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
+4 On WAGNER OEX Pads. They are listed as Heavy duty, Love mine. No dust and work well in the rain ! And I have Wagner E Coated rotors, Very happy with them
Hemi395
Cape Cod MA
I had the OEX along with Wagner Ecoated rotors after my factory rotors warped. Very little dust and I got about 30k out of them before the rotors rusted pretty bad. Now I'm running the Powerstop Z36 pads/rotors.The Powerstops grab better and just overall brake better than the OEXs. Very little dust with these as well.
BUT the OEXs are damn good pads, I only went with the Powerstops over the OEX because I tow my camper several times a year and the Powerstop Z36s are designed for towing. So if you don't tow a lot, I'd save some money and go with the OEX.
daveray9
The powerstop rotors rust at all? I went w the eline r1 concepts with the rust proof zinc. 1 New England winter later they are all toast.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
What is the Alfa procedure to bleed the ABS?
Hemi395
Cape Cod MA
I've had them for over a year and the zinc coating is starting to powder up a bit but definitely not rusting. I fully expected them to be rusted more by now....
turkeybird56
Central Texas
Thanks
If U stay with STOCK rotor: Wagner.
If U change Rotor to ie., Powerstop Rotor = Powerstop Pads.
All IMHO.....
Ricko
v8
How do you know if you have the start/stop system?
Mike Townsend
I put the R1 Concepts Geomet rotors on my truck a year or so ago and they brake performance is awesome. They don't rust either so that is nice.
Captain Bart
345 HEMI
I am puzzled as to vleeding brakes, and using an ODB II to figure it out? As long as I have being doing brake jobs, the calipers pistons are pushed back with a C-clamp, pads replaced, caliper re-installed. Fluid pushes back to the master cylinder......?
