Brake Swap Question
tourdemon
Hi all, need some help. I am doing the brake swap from an 05 SRT QC. I have both front and rear calipers, spindles and rotors. The front should be easy mount and get an alignment to SRT specs. My question is on the rears. Can I install the rotors and calipers on to my existing axle or do I need to swap it out with a Dana 60? I have a 4X4 so to swap the axle would require me to shorten my drive shaft, plus make sure the differential in the front is the same as the rear or I will have problems with 4 wheel drive. Any help would be appreciated.
OasisNinjaBat
