Broken Rear ABS Speed Sensor
eroemer
IN
5.7 L Hemi
Any suggestions on how to remove the plastic shaft from a rear ABS speed sensor? It is broken off inside the wheel. While removing it for replacement, it came out about 1/2" and then broke off.
2010 Ram 1500 4WD SLT
Brandon-w
Yukon
2015 Ram 1500
I took the hub off used a torch to burn the plastic shaft out let it cool and assembled with new speed sensor pickup.
Edit: sorry just seen it said rear. I'd use a small drillbit drill A hole in it and see if I could thread a screw into it and pull It out heat is also your friend but not too much.
Sent from my SM-A530W using Tapatalk
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
Maybe a small easy-out bit that would fit in there. Those would dig into the plastic and hold on for you.
Axegrinder1979
Maryland
I know it’s an old thread, but was unresolved. I has the same scenario and was able to wedge a 90 degree pick in and slowly twist with outward pressure to get it removed.
Orca
