BT Catch Can Installed!
VolsRam
Franklin, TN
HEMI 5.7
I just received my BT Catch Can today and installed it pretty quickly! I was hearing people talk about a spacer, but I didn't see one in the package, and the can doesn't appear to be touching anything. I also noticed other people crossed their tubes. I cut the tubes shorter and got them on without crossing them. The only trouble I had was removing the PCV rubber tip from back side of the engine. I just used some needle nose pliers and pulled. One thing I noticed after install is that can is loose from the Z bracket. I don't have an Allen wrench big enough to tighten it, but I will go by Auto Zone to borrow a tool and take care of. Looking forward to see how much this collects! I'll post pics tomorrow since it was dark after install.
09SMOKINHEMI
TEXAS
good stuff man.... the catch can is a great investment
VolsRam
VolsRam
Franklin, TN
HEMI 5.7
I'm at 3,100 miles now, so it's time for the first oil change. Since I'm changing the oil, I figured it was time to empty the catch can. And to my surprise, after only 22 days of driving, I had a lot of oil that would have gone into the intake. This is by far a great investment!!
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Nasty. It is sickening to think that without the can, you would have been pouring that junk into your intake manifold.
VolsRam
VolsRam
Franklin, TN
HEMI 5.7
I completely agree! Thanks again for hooking me up with the product! I am hoping to place more orders in the future: 85mm TB and a tuner. I'm just worried about having my warranty voided from them.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The TB wont have any affect on warranty as we use genuine Mopar throttle bodies and only port the inside. This means, the dealership would have to remove the TB and measure the inside to even see that it wasn't stock.
The tuner can cause a little trouble with the dealership depending on the severity of the repair. Most dealers don't care as long as you set the truck back to stock before taking it in.
VolsRam
VolsRam
Franklin, TN
HEMI 5.7
So how hard is it to set back to stock? I've never owned a tuner before. Also, can tire size, gears, and other mods be entered into the tuner to correct the speedo?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
When you plug the tuner into the ODB2 port under the steering wheel, there will be a menu option where you select the tune. If you have the tune installed, you simple set return to stock, and then it will walk you through the uninstall process (which is the same process you would go through to load the performance tune). It will correct the speedo for larger/shorter tires, change shift points, rev limiter, speed limiter, allow you to disable MDS, and more.
