UPR Catch Can drain plug stuck
Abrams117
Kansas City Metro
Just got my UPR catch can delivered and I ordered it with the drain line kit. My problem is that the drain plug on the bottom of the catch can that I need to remove to install the drain line kit will turn the bottom piece of the can when I try break it loose. Can't get a grip on that lower piece to prevent it from turning. Any ideas?
Daw14
Maybe a strap wrench ? Or chuck gently in a vise .
Ram Night
Southwest, Michigan
Try using a strap wrench to hold the can. I have used them 100's of times at work taking cylinders apart. They are a wonderful tool to have in your tool box.
Cableman
Longisland
Bet an impact driver with just holding the can would break it loose, as long as ya have the hex bit
