bullydog traction control not turning off
operator
Professional Firefighter Captain
Marrero, La
guys does anyone else have this issue I have the bully dog triple gt on performance tune and traction control disabled but it seems like its still on even on wet surfaces unless I hit the traction control button off but this is only in wet conditions on dry pavement don't even chirp just hook n go.
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
You've got to turn it off on the Bully Dog and turn it off on your truck.
operator
operator
Marrero, La
ok I disable it on tuner and in truck think turning tow haul on will help
Lhemi
OKC OK
It does on mine.
noah.nm86
The only way to disable it fully so you can chop nuts or do a burnout is if you disconnect an abs line or pull your abs valve fuse (which I did yesterday). Pulling the fuse put a number of lights in my dash and disabled switching to 4x4, when fuse was replaced all lights went out.
Sent from my SGH-I337M using Tapatalk
operator
operator
Marrero, La
I don't want to roast them just thought that I should at least hear a chirp or something but my tires bite every time and it just takes off I can do a brake stand but was just wondering if from take off was it normal to not spin a little. thanks for the input
Lhemi
OKC OK
If I turn both mine off I roast the tires into second. But I have the R/T with the 4:10 and 2800 stall...
