89grand
- Dec 11, 2019
- 415
- 494
- Location
- Phoenix, AZ
- 2019 RCSB
- 5.7 Hemi
I've heard a lot worse, but I've heard and owned a lot better than the basic factory 6 speaker 8.4" Ram setup. This is going in a 2019 single cab.
I've ordered the following:
JL Audio ACS112LG-TW1 which is a sealed enclosure with a 400 watt built in amp.
https://www.jlaudio.com/collections...-powerwedge-amplified-subwoofer-systems-93335
CDT Ram setup which is four 6x9 woofers and a pair of wideband 2" drivers for the dash.
https://www.cdtaudio.com/carspecific/dodgeram.php
I'm going to get an Audio Control lc2i pro and Kicker Key 200.4. I'm going to use the front factory radio speaker outputs to the Audio Control, then front out of it to the Kicker Key, the sub output to the JL Audio subwoofer, and use the factory radio to power the rear CDT 6x9's. The Kicker Key will run the door 6x9's and dash wideband drivers bi-amped. I may add an Audio Control Epicenter, as I already have one, and like them a lot.
I had considered going deep into DSP with a miniDSP, but it is expensive and time consuming, so I'll probably just use the Kicker Key. I have a Key 180.4 in my Jeep, so I'm familiar with it. I was going to use a Key 500.1, but it doesn't do any worth while tuning in my opinion, unlike the 180 or 200.4, so I bought the amplified JL sub instead.
I'll update this post as progress happens.
