I finally finished the install of the Kicker Key last night. My Epicenter and subwoofer still isn't completed yet.
I have a couple of my pointers on the Key amp. I took the head rest off and put the mic on the seat without it. I think it would be too high other wise. Second, if you don't completely like the tune, like in my case, too soft in the treble, you can adjust things and rerun it. In my case, I took the treble down a few notches on the headunit and reran it. Afterward, the treble was were I wanted it. I could have just boosted the treble on the headunit, but I wanted the tune to sound good with the tone controls flat. You could do the same with the bass. If it's too much, boost the bass slightly and rerun it. Not enough bass, lower it in the headunit and rerun it.
So how does it sound? Fantastic actually. I could almost tolerate it without the sub, but it will only get better when I finish installing it. Imaging is spot on and is above the dash, about at the center of the windshield, and the eq seems pretty spot on as well, after my initial treble tweak. You can't adjust the tune, but even if I could, I'm not sure I would. You could probably get better results from a DSP unit and many, many hours of tuning, but it wouldn't be a big improvement, and that's where the Key shines, 5 minutes and done with a very good tune.
Oh and it's loud too, 50w x 4 is plenty of power. Level matching between the door and dash is great, but you could adjust that with the gains if needed. I had to bring the gains up after the tune, as the LC2i was at it's ideal setting before the Key amp was loud enough. Took about 15 minutes to get dialed in. I'm not sure why Kicker recommends running the auto setup with the gains all the way down, since they'll likely be too low after.
I really think this amp is the best bang for the buck for sound quality improvements. For $250, nothing else you could do would improve the sound more. I think this would be a big improvement on the stock speakers as well, although not as good as better speakers and the tune.
If I had the choice between the Key and stock speakers, or aftermarket speakers ran off the headunit, I'd take the Key and stock speakers.
