Rob30
I have been getting a C1073 code lately, the ABS and traction control lights are on. Cruise control is not working. I have checked the ABS fuses, all are good. I have power to the harness on the pump control. At this point how do I check the pump to see if it is working or seized? I don't have a wiring diagram. Is there a way to jump it to see if it turns on?
I did the back brake pads a couple months ago. The lights went out for a couple days. I am wondering if the valve body is full of crud and preventing the pump from working, causing the code. If that's the case, should I try opening it up and cleaning it out, or maybe just bleeding the system somehow? I want to exhaust all testing before pulling the pump and controller off and replacing. It does not look fun and pretty expensive to replace.
