Cabin Air Filter Mod
mtnrider
Georgia
I did this mod a couple weeks ago using the Geno's kit. Didn't last more then a few days before I pulled it out. Restricted the air flow in my Mega too much. Pretty much had to run the fan wide open to get any decent air flow out of it. Not sure if the newer trucks have a better fan but it didn't work well in my 2016.
I might try a make a higher flow filter (something like a metal mesh you find in a stove top vent) just to keep the big stuff out but maintain they air flow?
Ramnewbie
I have a 2018 Express I just purchased. So my truck should have the filter? Or is it only higher models such as the Big Horn?
I will look anyway, but had to ask. :p
My 17 express already had the filter.
Sent from my XT1650 using Tapatalk
chum
US
ecodiesel
A must mod, just did mine with k&n reusable filter. we'll see how that goes.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
No kidding, On my 2015 very little difference! I also tested it with a air flow meter ! Curious if maybe your fan is a little weaker for some reason or crude on the coil ?I will do a air flow test again soon with the old CAF. No CAF and a New CAF and pay close attention
MK96
SK
Cabin filters are designed to work this way. I put a filter into a car that wasn't designed for a cabin filter and flow wasn't reduced.
Marlinmate
For everyone that's done this mod, remember to check your filter. I just replaced mine after about 12 months and damn it was filthy!!!! I just installed one of the Fram filters with carbon and baking soda.
What is the Fram Filter model number w Carbon/Baking Soda ? 2015 Ram
2018NightRam
LA
So what year did they start putting it in our trucks?
TonyMM
2016 RAM 1500 CC 6"4 4X4
And here mine after 15k km...
Just replaced it with a fancy one from Fram, the CF11671 with baking soda...will see if this is worth it...
TonyMM
Looks like it wasn't pitch white to start with.
Sent from my SM-N960U1 using Tapatalk
Oh yes 100% white when it was new.
I really did not expect to see so much black after 15k km...
TonyMM
In that case funny how yours is all evenly colored dark with dirt and mine isn't.
Yes I wondered about that also as I saw yours [emoji15]
TonyMM
I'd get that checked out if I was you [emoji1787]
[emoji3][emoji3]
Are you sure there isn‘t any piece of plastic etc.... in the cabin filter area as the filter should be evenly coloured with dust etc....
TonyMM
WOW good to know! Thanks.
I wonder why you guys have only one part of the cabin filter used??
Out of 3 new cabin filters you can make a new one for free .....LOL.....
Superj
AZ
Guys, need your help.
Just did my mod today (with bruises and cuts on both hands....) with a boxcutter.....(2012 Sport)
Anyhow, maybe an advise from one of you.
The filter door cover fits perfectly and also seals the filter opening, BUT, I tried and pushed as much as I could, I am unable to latch the door on both sides. It simply doesn't snap in.
I checked for the littel plastic hooks on both sides of the filter housing and they are there.
Is it possible that they are maybe a little bit too long, and that I need to rasp off a bit of the plastic latches from the filter door?
Anyone had a similar issue?
