Colin15
Hey first post here. This isn't going to be very well written. I just did a cam swap on my 2015 ram and figured I'd post how I got the oil pickup tube bolt back in without dropping the pan. Hopefully this will save someone else a headache.
I didn't take pictures or a video cause I didn't wanna try it again.
What I did was put a rag into the oil pan then wrap 10 wraps or so of fishing line around the bolt by the head with 2 long tails (wrap it so when you pull the bolt will spin the right way). lined the bolt up and pulled the line.
*Edit* put the bolt in the pickup tube before putting the oil pump back on. I put a small magnet on top to hold it there. Then twist the oil pump so it lines up again remove the magnet and align the bolt using your fingers or the fishing line
Another tip for removing the MDS plugs. If you're not going to reuse them just snap the top off. There's a small cylinder in the middle that's hollow in the middle and has a notch in either side. Stick a small flathead in the notch and put a screw in a little bit. Then I used one of them nail puller screwdrivers to pop them out.
Cam removal - I found that my cam was binding while trying to take it out and would only come out if cylinder 1 was TDC.
I'll keep adding more as I remember the problems I ran in to. I took pictures of some of the things but don't know how to post them. Hopefully this will help someone out.
