Can I install a 2014 pcm on a 2015?
Thewetdream
2022 Dodge Ram Big Horn Crew Cab 4x4
Hey guys!!! I'm a long time follower but just decided to sign up because I finally own the truck that I can really enjoy. I've owned a 2012 Ram but currently upgraded to the color and engine I've always wanted. That being said one of the modifications I wanted to do was tune this truck , after doing research I have found that in order to tune I will have to purchase a unlocked pcm blah blah blah then plug in the tuner ..... I see you guys talk about this a lot but I can't see if anyone has brought up this idea..... My new truck is a 2015 ram express 1500 4x4 with the 5.7 and a 8 speed auto. The first year Ram locked the pcms. Is it possible...... to just purchase a 2014 ram pcm for the 5.7 with a 8 speed auto and simply plug in a diablo trinity and run their tunes or tunes from any other company??...... this would cut the price from 1200+ to maybe half the cost and I would be able to install my original if I had to for warranty purposes. Just picking your brains..... if I got to spend the 1200 and that's my only option then so be it. I plan on doing a zone 6 inch lift with 35 12.5s and would like it to be as peppy as it is now after the lift is installed. Thank you for you time..... I look forward to trying to contribute to the Ram forums as well!!!
The silver ram is my old one and the black one is the new guy
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
I do not know if the tuner can override it, but any PCM swap is going to need to have it VIN programed to work regardless.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
A 2014 PCM will not work. You will need to either buy an unlocked 2015 PCM, or send your 2015 PCM in to be unlocked.
Thewetdream
Thewetdream
Thanks fellas I figured it wasn't that easy...... if it was ..... everyone would be doing it.
Thewetdream
Thewetdream
Do you own Moe's? If you are I heard great things and will be buying your 87mm throttle body as soon as I do enough research for the best cold air intake to match it to that's under $400.00 beans
quietpeen
2021 TRX
Hellcat
Yes he does. Very knowledgeable and great guy/businessman.
