Cant figure out what the issue is...
DodgeRam04
my 04 1500 hemi is acting strange lately. Sometimes when I crank it up, it sputters when I hit the gas. May last a minute, might last a couple of miles. also whenever I take off a little faster then normal, it changes gears like normal but during the rev it will take off from me like I just punched the gas harder but didn't. it happens randomly. So I changed the plugs and wires, cleaned the throttle body, and air filter. No codes are showing. I've tried everything I can think of but nothing seems to work. please help.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Remove the battery cables for a few minutes to reboot the PCM, look for codes. After hooking up the battery, turn the ignition on without starting or touching the gas pedal for 10 seconds. Then back off then start normally.
Joey93
