Mister Luck
cassis tutissima virtus
- Joined
- Aug 25, 2020
- Posts
- 1,651
- Reaction score
- 591
- Location
- WEST COAST
- Ram Year
- 2016/2017
- Engine
- 5.7 V8
I don’t think you’ve ever been to Mexico or at least you never seen how they make Tecate.Highly unlikely. It is not like they push the trucks out behind the assembly plant and use tap water from a hose out back and some gallon jugs to fill cooling systems at the factory. The factory has a water distilling system to produce distilled water which is then mixed with the coolant concentrate from a gun much like a soda fountain. The sand would have to somehow make it past the multiple mechanical filters and then somehow be levitated by the column of steam in the distiller. Once it did that it would have go though the passage ways in the dispenser without causing problems in the dispenser system.
