CEL and Oil light
Northy
2012 ram 1500 sxt cc
hi all
I have a 2012 ram 1500 sxt with a hemi
When I am randomly driving my cel and oil flash ding twice and goes away.
Does anyone know what may cause this as it does not stay on and goes away. it is driving me nuts but only has happened a hand full of times. I am just trying to think of possibilities as to the cause
thanks in advanced
N
Northy
my cel doesnt stay on to indicate anything. just had a fresh oil change in thebeginning on January and it still reads in valid range
huntergreen
if the cell came on there should be a stored code. i would be worried about the oil pump. that goes so does your engine.
Burla
2010 Hemi Reg Cab 4x4
Maybe the guy who changed your oil didn't clear it? I know you can clear it in my 2010, I dunno about 2012. Turn gas to last position before it starts, then turn off, press gas pedal 3 times and then start truck.
N
Northy
It's not stored I've checked with my reader .. says nothing valid ..
huntergreen
are you reading normal oil pressure on your EVIC ?
savage_46
Alaska
6.4 swapped
Oil pressure sensor are a common problem with sending false readings, usually sets P0520. TSB says to replace the sensor if that DTC is present. Other things could be incorrect oil viscosity, or oil level too low or high. Also, was this happening prior to your recent oil change?
N
Northy
That is correct only been happening so last Oil change .. not sure if there's a way to prove the dealer put the wrong oil .: may just change it myself as warrenty is up in 30 km
savage_46
Alaska
6.4 swapped
Check your invoice / receipt. The part number, quantity, & description should tell everything. If in doubt, call them up
N
Northy
Yah I called and I did check my last invoice stated 5w20 .. but still may just change it myself because they can say they put it on paper but may not of in person
