CEN code P0430 and P0507
cmm47172
2008 Dodge Ram 1500 ST Regular Cab
3.7 L V6
I have a 2008 RAM 1500 with 3.7L V6. My truck recently quit twice when coming to a stop light. My CEN light came on showing CEN code P0430 and P0507. I changed out the spark plugs because I was due for a new set. The old ones were gapped really wide. Anyway, I ran the truck for about 2 weeks without issue. This morning when stoping at a traffic light, I could feel the engine stumble like it was going to quit again.
Anyone have an idea what may be causing the stumble and triggering the codes?
Thanks to anyone who has input. It’s to cold to be having vehicle trouble so I would like to throw the right parts at it to make this issue go away.
MADDOG
Out Exploring Arizona
P0430 - Catalyst Efficiency Bank 2
Possible causes
Three way catalyst converter Bank 2 failure.
Exhaust tube or intake air leaks
Fuel injectors may be faulty
Fuel injector leaks
Spark plugs may be faulty
Improper ignition timing Engine Control Module (ECM)
P0507 - Idle air control system
Possible causes
Leaking air intake after the throttle body
EGR valve leaking vacuum
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Failed EVAP system Failed IAC (idle air controller)
Faulty IAC circuit
Several things come to mind when I see these codes pop up together, They are related to intake air or vacuum issues:
1. The throttle body is dirty. If it is, clean it.
2. You may have bumped an EGR or PCV valve feed tube or rubber line. Check them to make sure they are in place and not cracked.
3. The EGR valve, which usually throws an EGR type code, may be failing.
4. The PCV valve should be replaced.
I am going to assume you got the plug gap correct because if you didn't, you'd get a P030X code.
I'd start with a visual inspection of the vacuum, EGR and PCV valve lines, replace the PCV valve and clean the throttle body.
cmm47172
cmm47172
3.7 L V6
Thanks for the reply. I will check out this stuff this weekend if it will keep running. I will post an update when done. Thanks again buddy!
cmm47172
cmm47172
3.7 L V6
Do you know where I can find a diagram that show where the bank 2 sensor is and which one is failing i.e sensor 1 or 2? Or a diagram that shows the location of the EGR & PCV Valve is?
cmm47172
cmm47172
3.7 L V6
Any response to my last question would be greatly appreciated. Happy Friday to All!
cmm47172
cmm47172
3.7 L V6
I replaced both right bank sensors. They were completely toasted melted metal. Worst I've ever seen. I also tightened up all vacuum connections. After clearing the check engine light codes and taking the truck for a 15 mile trip, I'm no longer getting the P0507 however, I'm still getting the P0430? Does this mean I need to replace the catalytic converter? Is this a job I can do myself with muffler clamps or am I going to have to take it to an exhaust shop and get it welded on?
xtremewlr
Tucson, AZ
It might depend on where you live but I think you have to have them welded on.
cmm47172
cmm47172
3.7 L V6
sounds like I'm getting ready to spend a bunch of money. I'm thinking about running a bottle of CATACLEAN CATALYTIC CONVERTER & FUEL SYSTEM CLEANER first. Anyone have any luck getting rid of P0430 with this stuff?
xtremewlr
Tucson, AZ
Never heard of it but it's worth a shot. Best case, it resolves the issue. Worst case, it destroys your cat but since you would be replacing it anyhow....
cmm47172
cmm47172
3.7 L V6
CATACLEAN is about $35 a bottle. Maybe that money would be best spent toward a new cat.
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
Hey,Maddog I have the po 507 code it is a gremlin that has blown my mind i have replaced or check for vacume leaks there are none .This is what stump me I can clear the code and drive it runs fine i can turn to the left going through a drive though and it will give me a check engine light and when checked po507 code the thing runs like a sewing machine I have read to check the power stearing pump pressure switch well the 05 ram 1500 doesn't come with a switch the computer regulates the idle i also some guy traced it down to the power stearing oil cap if anyone have a idea feel free to speak up.Thanks and May our Lord Bless.
cmm47172
cmm47172
3.7 L V6
I’ve decided to replace the “Y” pipe that has both cats. I looked under the truck today and it appears it bolts to the manifolds at one end and clamps at the other end to the pipe that leads to the muffler. My eyesight is not so good but it doesn’t look like it is welded anywhere. Does anyone know if I am correct that no welding is required and that I can simply unbolt the whole thing to swap it out?
