Changed oil now truck shaking with codes HELP
gerald T1980
Hey guys, just had my oil changed on Friday. Everything was good until today.
Truck is shaking and at times when I accelerate, the engine light flashes.
I’m getting these 3 codes now:
P0306
P1416
P3497
Im hoping it’s just spark plugs.
Any of you ever had issues like this following an oil change? This never happened before.
It’s a 2021 Hemi with 60k miles on it.
chri5k
USA
Diesel
First code is cylinder 6 misfire. The second two codes are related to the MDS solenoid system not activating and/or deactivating properly. Besides electrical issues with the MDS system, low oil pressure is a possible cause. Did you check the oil level?
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
P0306 Cylinder 6 misfire​
P1416 Dodge Code - Cylinder 6 Reactivation Control Performance​
What are the Possible Causes of the DTC P1416 Dodge?​
NOTE: The causes shown may not be a complete list of all potential problems, and it is possible that there may be other causes.
  • Low oil pressure or blocked oil passage
  • Faulty MDS Solenoid
  • MDS Solenoid harness is open or shorted
  • MDS Solenoid circuit poor electrical connection
  • Faulty Engine Control Module (ECM)
  • P3497 Dodge Code - Multiple Displacement System Rationality Bank 2​
    • Low oil pressure
    • Restricted oil passage
    • Engine mechanical condition
    • Multiple Displacement System (MDS) Solenoid fault
turkeybird56
Central Texas
Who did your oil change? Kinda strange all this after a change. Was any wiring played with, or something done on the PAX side of the truck? Like "chri5k" said, best check that oil level, also look at filter and insure drain plug in and not leaking too. Then do a visual and look at all coil packs and see if things look disturbed also. Also, look at your ECU, should be right next to battery. Make sure it looks like the levers holding in the wiring looks OK and nothing maybe spilled all over it, like oil. Something just not jive, so these ideas just Internet Guessnosis.
RamRod37
Georgetown TN
since the common thing here is low oil pressure and oil was just changed check oil level but could be too the MDS solenoid for cylinder 6 went down
Dodge 1500 4X4
Rochester, NY
Could be your oil filter is not going to bypass or stuck I would change that out seeing it was fine before the oil change, make sure there's 7 qts in it, also check the connection of the oil pressure sensor on filter housing.
G
gerald T1980
Not yet. I’ll check in the am and make sure. Thank you
Oil change was done by my mechanic I’ve been with for 10+ years. Nothing out of the ordinary done.
I’ll check all the other things you mentioned and see if there’s something there.
I agree, very odd everything was working great before the oil change and all of a sudden this.
Thanks for the help
I’ll tell the mechanic that. Thank you
I used a mobile oil filter for the first time ever. I’ll double check the oil level tmw and find out about the rest.
Thank you
BenchTest
Midwest
Keep it simple to start. This happened in close proximity to your oil change. Verify oil level is correct. What does you oil pressure gauge display with a running engine? If flow is restricted, you should be seeing a change in operating PSI. If all of that checks out, do a scan under the hood for things in proximity to oil filter location (looking for spilled oil, presence of a leak, disconnected wiring/hoses/etc).
G
gerald T1980
Yup. I agree.
Oil pressure gauge shows just a touch under 100%.
I’ll look in the am for any spilled oil or a leak etc. I know there’s no leak coming from under.
Thank you
There's been problems with Mobil 1 oil filters W low oil pressure.
Interesting. Could that be the issue?
Just researched and looks like the mobil 1 filters can cause pressure to go up. I wonder if replacing the filter with a different brand you guys recommend might fix the issues?
BenchTest
Midwest
Yup. I agree.
Thank you
Not sure what "oil pressure gauge shows just a touch under 100%" means. Are you referring to Oil Life? Oil pressure should read out in PSI, a numerical value indicating the pressure.
RamRod37
Georgetown TN
I have seen Mopar do weird stuff on wrong oil weights since you changed filter/oils I would start with going back to what you was using
Tulecreeper
Sthrn AZ
Yup. I agree.
Thank you
Oil pressure is in PSI; oil life is in percentage. I don't know what your pressure should read, but on my 6.4 it runs about 53 PSI at highway speed.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
Step 1: Take it back to the guy who did it. Step 2: Report back here with results.
G
gerald T1980
Ah ok. How do I check the pressure?
I hear you. Odd this happened though
Lol wish I could. I recently moved about 4 hours away from him. I happened to be back in the area and went to see him and thought I would do my oil since I was there. I chose the oil and filter.
BenchTest
Midwest
Should be a gauge for that.
BossHogg
Oakland Township, Michigan
6.7L Cummins
Yup. I agree.
Oil pressure is usually measured in PSI.
Could an incorrect oil type have been put in your engine? This could result in a drop in pressure depending on its characteristics. Just thinking out loud.
Tulecreeper
Sthrn AZ
Either your analog gauge on your cluster, or you can page through the menu on your EVIC until you come to the "Vehicle Info" page then use your right/left buttons on the steering wheel until you come to the "Oil Pressure" reading. Should read somewhere between upper 40's and lower 50's PSI.
Burla
2010 Hemi Reg Cab 4x4
If the oil level was full 99% this is the issue, it should have been common knowledge just change this the second you had an issue after an oil change. The orange can of death is a real thing, dont drive the truck til a new filter is hanging on it. Mis well go to oil stop and just get another oil change. If m1 uses louvers could be closed louvers in center tube as well.
OasisNinjaBat
