Getting started on my audio build this week. The equipment list is as follows:
Processing:
JBL MS-8
Amps:
2x JL HD 900/5
1x JL HD 600/4
Speakers
2x JL w6v3 woofers - passive crossover via 900/5 amp from bridged rear input from MS-8
1x JL ZR800 midbass in front door pods - active crossover vis the MS-8
1x JL ZR525 component in front door pods - active crossover via the MS-8
1x C5 625 component in rear door - passive crossover via the MS-8
The ZR800s will be bridged from the front channel of the 900/5s, the C5 650s will be bridged from the rear channels of the 900/5s, and the W6v3s will be on the sub output with input from a split channel from the ZR800s which will receive a 20hz-400Hz signal from the MS-8 and the 900/5 will use its built in crossovers to split the signal. The ZR525s will run active crossover through the MS-8 and powered by the 600/4 so each component will be getting 150W, should be pretty sweet.
I had originally planned a rear wall build but I couldn't get the HD amps and the MS-8 all onto the back wall without them preventing the seat from even bolting into place...so I modified slightly. The MS-8 will be on the back wall along with all the wiring plus a few other electronic devices used in the vehicle that can now be out of sight like my RGB LED controller so I don't have to find a hiding spot for it anymore.
Here was the original idea, with only 2 of the amps installed:
Made some changes to the layout and it's now the 3 HD amps on the floor angled so I can now play with the crossovers and filters as required without having to pull the seats like I would have had to before.
Now that the test fits are done I'll be starting the fiberglass work to smooth everything out and make it look presentable. That will happen tomorrow.
Started making a place for the MS-8's remote display. I'd already smoothed out the area under the center stack so I just trimmed out a hole big enough for the display and then began fiberglassing the remote into place.
That's it for tonight. Tomorrow will be continuing on the center stack that I'm also fabricating in a few gauge pods as well as potentially getting going on the door pods while the truck's in for some exhaust work.
