Check your BellTech front shocks!!!
The Q
South Texas RGV
2014 Sport R/T
As most know, I installed a BellTech 964SP 2/4 Lowering Kit on my 2014 Sport R/T. At first I had kept the stock front shocks because I had read some reviews on other forums that talked bad about the BellTech Street Performance front shocks.
Well, curiosity got me and I installed the BellTech Street Performance front shocks. At first I couldn't tell a distinct difference between the stock and BellTech shocks, but the more I drove the more I felt the BellTech's were softer. I had it in my mind I'd swap them back on my next days off.
This past couple of days I was hearing a squeak sound when I hit bumps. I only really came to hear this as I was curious if my lowered suspension was making any noises, so I rode with the radio off and the windows down a couple of times. I could have sworn the sound was coming from the rear of the truck. I crawled around under my truck's rear and couldn't find a thing loose or out of place. I then lifted the front and low and behold, I found what was making my squeaking sound. The lower portion of the BellTech shock had worked it's way off the rubber of the lower shock mount on BOTH front shocks. You'll notice scratches on the lower shock mount, that's from install where I used the cement to compress the shock so I could get it into the A-arm since I didn't have the truck lifted high enough. Here are some pictures of what I found.
Dubstep Shep
Houston
2014 R/T
GEEZE. It seems like Belltech is leaving themselves a ton of liability with that design. Wouldn't be all that hard to fix.
SILVER_BULLET
hmmm ill check that out today mine squeeks alot but i think its coming from the end links on the sway bar
The Q
The Q
South Texas RGV
2014 Sport R/T
That's exactly what I thought too. I was thinking end links because BellTech's design is so different from stock.
The front shocks were hitting the lower control arm just enough to make noise. I just took the truck out for a test ride on a really bumpy street and there was no squeak at all.
DavidRam
SoCal - Redondo Beach
2012 RCSB
That sucks... I am gonna check mine too. Thanks for the warning. Are you gonna put your stock ones back in???
Personally, I am about done with the BT shocks, and I am close to ordering the QA1s...
SILVER_BULLET
I'll have to really check it if that's the problem then they're coming off and stock is going in again
BlkRamRt
SoCal
HEMI 5.7
Mine squeeks too but it sounds like it comes from the rear.. Guess I am going to have to check mine too.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Weird, have you contacted someone at BT? Most of the guys the have been super nice with my questions...
I sent your post and pics to someone there...will let you know.
BlkXpress
DFW, Texas
I ran into this issue about a month ago... except didn't see it as early as you. I thought I was going crazy with how bouncy my truck was... and then I heard a snap.
Belltech fed ex 2dayed me new ones....
Here's the old
The Q
The Q
South Texas RGV
2014 Sport R/T
Stock shocks are back on and an email along with pictures sent to BellTech. Think I'll stick to the stock front shocks for now. The rear BellTech "seem" to be doing okay at the moment.
Graygoose
Oklahoma
Convert, for now.
small
I got an email back. R&D is working on a fix and solution now. I forwarded your post and pics to them.
14RAMRT
Dafuq! I also agree the shocks seem softer. I'll check mine when I get home later
Graygoose
Oklahoma
Convert, for now.
small
Thanks!!! Hope they can come up with a fix.
I'm sure they will, he said they recently have seen it on the SP shocks, but not on the ND2...so it should be an easy remedy.
14RAMRT
Just crawled under the truck real quick and mine look fine so far. Haven't driven it hard on curvs yet though. Just pounding pavement and straight line pulls.
joeg45
Katy, Tx
This the reason I switched to qa1 shocks i had one like yours about halfway off and the driver side the bushing was in but the t-bar had snapped off on one side thought I just got a bad set
-Arana-
Houston (CYP), Tx
Look up Houston mopars on fb bud sorry for the hijack
UNBROKEN
2012 Ram R/T
Mine did it too. I posted about it last week when we found it at the alignment shop. I pushed them back in and so far they've stayed in place.
Graygoose
Oklahoma
Convert, for now.
small
Ironic, crawled under my truck last night, have maybe 300 miles on them, and my passenger side did it too.
Orca
