Chirping/Whistling Sound with Slight Sputtering
MaxSteel2013
Vehicle: 2017 Ram 1500 about 55k miles
Engine/Upgrades: 5.7L with Whipple Supercharger
Problem: While driving under some load I hear a chirping/whistling sound coming from the passenger side of the engine bay. The sound is non existent at low RPM, and non existent at high RPM (full throttle). I've replaced my throttle body, cleaned my intake, replaced the filter, swapped manifolds to headers (not related in theory, but I had them sitting around). I'm at a loss for what the sound may be. I've not been able to successfully capture it on video. There is a slight lurching feeling while the sound is happening. I thought for sure it was intake being choked up some. I'm at a complete loss at this point. Could this be a leak in the blower gaskets?
Daw14
Idler pulley, alternator, water pump. Get a stethoscope from harbor or use a dowel to test pulleys ,alternator.water pump any other front driven accessories. May remove serpentine belt and see if still persists.
MaxSteel2013
MaxSteel2013
I appreciate it! I'll play around a little. Sound doesn't happen at all at idle.
