Cluster back light diming
Bam930878
Illinois
I know this may have been a previous thread but my 13 ram 1500 is currently having the dash cluster screen rapid dimming issue it has yet to completely shut off just rapid dimming i have already tried pressing and fully seating all fuses any other recommendations
tron67j
Maryland
Is this when you are adjusting the dimmer switch, or all by itself? If the latter, have you made sure the dimmer wheel is on full brightness? That would be all the way up then back off one click from the interior lights being on. It is possible the switch is bad and causing the dimming. I hate to throw money before diagnosing actual problem but this isn't an expensive part, I think. If you can't test it, you can private message Benny at All Mopar Parts in Vendor Section to ask for cost.
B
Bam930878
Illinois
It doesn't make a difference on the brightness setting but the dimmer does appear to work as it does get brighter and dimmer just flashes randomly
Ken226
Washington State
This is a common issue. It happened to me as well.
There is no fix that I know of, other than replacing it.
If you do a search for "instrument cluster flickering", or similar, you'll find tons of threads on the issue.
I replaced mine with a used one from Ebay, and used AlphaOBD to program the mileage. I also bought the 3" evic version as a backup.
