ScubaSteve42
2012 Ram 1500, 66k, 5.7, vararam/magnaflow catback/tuned.
Hey, all. I appreciate all the info on these forums, and have been having trouble finding more info about some issues with the Ram.
Normal daily driving doesn't come with any issues, but when I "get on it" with some above-average acceleration, I'm getting some kind of failure/misfire. At first I thought it was a transmission issue, since it sounded like the truck was downshifting before taking off. The truck would start accelerating normally, then let out a "WAAAAAAAAAATTT" without accelerating, then after a few seconds something would kick in, and the and the truck will take off. Took it to the dealer (right before warranty expired) and he said tranny was fine, but I needed to change my plugs. Plugs are changed, but the problem persists. While I was at the dealer, I had the exhaust manifold repaired, and haven't had any ticking.
To me, this means coil packs are bad, but I don't want to rule out lifter failure. I'd rather not replace good coil packs, and still have the issue.
about 70% of the time use the "shift to 6th" trick to knock out the MDS. Although, I've experienced the issue whether MDS is active or not.
