Comp 268 is IN....
T
truckin151
2013 sport
I believe I got a pic of the heads, it wasn't thick just a sticky gooy film almost on them. The valves and pistons looked fine though.
sawcut64
Arlington/DFW Texas
If it was just a film and not caked up sludge in and around the heads and valve cover then that's normal for higher mileage. I've seen in on most Hemi's I've cracked open that had some miles on them.
T
truckin151
2013 sport
Well thats good to hear. Now I just have to worry about getting it to idle in drive cause it wont. Nothing like pulling across traffic to fill up and have it stall halfway into the road cause you stopped.
T
truckin151
2013 sport
Well I took the tune he sent and bumped up the idle myself 200rpms and now it wont die at stops, still surges a little but doesn't stall.
Silverbullet08
Persona Non Grata
oh there is a set of inertia performance heads for sale for 1300 if your interested...
T
truckin151
2013 sport
No I think Im done for now once we get it running right. Besides I either want some BV heads or the 09' eagle heads
T
truckin151
2013 sport
Oh Got another video uploading now, one thats a little better than the one I did last night
T
truckin151
2013 sport
Its "processing" so give it a minute, should be loaded by the time I get back from the store
glass3222
Central PA
glad you got it done. Once you get the tune worked out, do some runs and let us know what kind of improvement you get 0-60. How does it feel power wise?
The vid sounds good. How soon do you think you will be able to get the tune nailed down so you can get out and do some timed runs with it?
Silverbullet08
Persona Non Grata
nice! yea thats the same thing that happens when i rev it. the rpms bounce around after that...
T
truckin151
2013 sport
I have 4 tunes from hemifever right now to try and load up. He said from a tuners perspective, it looks perfect though. The fuel trims are right where they should be, the idle is right where it should be everything looks right... Its just the surging issue. I am going to reset the throttle body and see if that helps.
T
truckin151
2013 sport
I am actually thinking of putting the stock TB back on and seeing if that hleps it out. I have had issues like the surging with my truck with only the ported TB so that might be the cause.
Have you still had surging issues even after getting rid of the knife edge?
JustinRam1500
