Confused on which Mopar windshield wiper fluid to run
gregshin
NA
NA
I went on google and saw that Mopar had a green, blue, and purple fluids.
can i run the purple fluid? i believe its a repellant.
Padilen
Im not sure this is a real question but if it is:
The color isn't important it's what's in it. In cold climates you want stuff that doesn't freeze. In warmer climates you don't need fluid that doesn't freeze but maybe cleans bugs better. Or rain sheets off.
And you don't need to buy MOPAR labeled fluids.
develand
Cant decide?? Mix it all together and call it a day! Boom, problem solved!
Administrator
You should just pay the dealer to fill your windshield washer fluid so they can't deny your warranty when your transmission pukes.
RodRam
Ga.
Why run mopar? They don't make wiper fluid they buy somebody's cheap stuff and it's branded mopar. Google best wiper fluid and by best on its rebeiws
R.L.K.
Bristol , Tn.
Just run the blue stuff from a gas station , in the winter run the blue stuff that doesn't freeze.
Some have reported running the rainx messed up the level sensor , maybe steer clear of it .
Sillygoose
Like mentioned, stay away from the rain x type
THETANK
up jor *** mang
2015 R/T
I use gas and it's the 87, don't start on the should I use the 89, 91 or 93. Save your money and use 87 especially if living in drier geographical areas. Geez typing geographical is time consuming.
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
Ohhhhhh My !!!!! :roflsquared:
baum
savage, mn
2015 Laramie
i just release my trunk monkey when i need a clean window. he gets out and wipes it clean for me :)
fordtech90
Jonesboro, La 71251
All u need is 50% water and 50% antifreeze coolant. Don't have to worry bout freezing and it should act like a water/bug repellent with its oily feature.
G
gregshin
NA
NA
man you guys are useless.
i heard issues about rain x but wanted to see what everyone here is using...no here's really given me a straight answer cept stay away from rain x.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
When I need a spit bottle, I pour the remaining water in the bottle in the reservoir. I am probably 50/50 water to w/s wiper fluid. Works fine. We get "Love Bugs" down here and nothing is taking them off of the w/s w/o scrubbing anyways.
AxleFolly
