Gottobecdn
- Joined
- Sep 15, 2013
- Posts
- 3
- Reaction score
- 0
- Ram Year
- 2010 SLT
- Engine
- 5.7 hemi
Woke up to a puddle on the driveway this morning. After a lengthy inspection I still can't fing the leak. Majority of lost coolant is on the frame rail directly below the crank, leading me to believe the water pump but nowhere around the housing nor the hole behind the pulley is wet. A wiring harness is soaked directly below the thermostat housing/temp sensor also.... All hose connections are good, definitely coming from the engine side and not the rad... Any ideas? Coolant temp is running around 204 (0utside air temp is 68 today) did peak at 206 at one point..... Anyone know what the preferred coolant temp is? One theory I have is high temp resulted in coolant blowing past o ring on temp sensor but honestly I don't really know what's going on.
2010 SLT, 5.7 Hemi
2010 SLT, 5.7 Hemi
