So I'm under the truck replacing the pitman arm and doing a trans filter and fluid change and I notice that I'm leaking coolant from somewhere that I can't see. It's dripping down the back of the oil pan (side opposite of the drain plug) and I'd say I'm losing about a quarter of a quart every couple days. My first thought was a freeze plug but the one that's behind the starter appears to be dry (although it is rusty looking) it's not coming from the flywheel area tho, it is definitely toward the engine side. Thanks in advance for any help.
1500 quad cab, 5.2L, 46re trans
