Odd water leak location
StingrYellow334
Montgomery, Alabama
Noticed a possible problem today. An area on underneath the passenger side of the engine behind the wheel well was leaking water. I looked everywhere as well as I could, and couldn't find the source. It's water, no oil, no coolant. Any ideas? It's almost time for the servicing, but I wanted to see if it's something simple or have the dealership look at it. Thanks16947416717143094592788383626582.jpg16947416717143094592788383626582.jpg16947417991314725569982294059038.jpg16947418430772731239506367896788.jpg16947416717143094592788383626582.jpg16947416717143094592788383626582.jpg16947417991314725569982294059038.jpg16947418430772731239506367896788.jpg
nlambert182
Huntsville, AL
If you're certain it's just water it's likely the AC drain. However, I had a leak there on my previous Ram and it ended up being a hairline crack in my coolant tank at the seam.
Daw14
Look at the fire wall , just to the pass side exhaust manifold . The A/C drain exits there .
turkeybird56
Central Texas
AC drain if U 100% sure it is just water. Also check inside pax area carpet and under dash and insure not wet, cause if your AC drain is clogged, that be a problem also.
CAVEAT: This is for 5th Gen RAM, earlier model years may have drains in different place.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
do you have a Sunroof on your Ram ?
There are at least 2 drain tubes at the rear of the front right tire.
the first one is from your A/C unit Condenser
It drips almost perfectly in line with the front door & fender line.
The second one is from a drain hose, that comes down from windshield, then under the hood cowl, then drains at a point below the firewall
Ftank
