Indeed it does. Is most likely broke and leaking there at the center. Is why it’s lose, most likely the spindle bearing done. Swap the fan clutch while your at it(cooling fan) Don't go cheap or you may find your swapping again in a year. https://store.mopar.com/oem-parts/mopar-water-pump-68346912abCooling fan and water pump pulley connection are wobbly. Also, smells fishy like coolant leaking. Does that mean the water pump needs replacement? 2015 Ram 1500. Thanks!
Thanks a lot Burn2k12Ram.Indeed it does. Is most likely broke and leaking there at the center. Is why it’s lose, most likely the spindle bearing done. Swap the fan clutch while your at it(cooling fan) Don't go cheap or you may find your swapping again in a year. https://store.mopar.com/oem-parts/mopar-water-pump-68346912ab
Gates is garbage.... go with OEJust found out, I'm in the same boat. My water pump went out yesterday. Looking at replacements and reading a lot last night, it looks like Gates branded stuff is supposed to be pretty good. Is there a reason not to use them? It's a considerable price difference from Mopar and all of the other brands.
I'd like to, but the dang fans are $400 for the OEM fan online.Do a V6 fan swap / Clutch Fan delete while you're in there.
The Dorman and TYC fans don't have a great rep. Check out the Ram facebook pages,you'll find several guys who've had issues with both fans. Is it worth cooking a motor because you cheaped out on the fan.Why are you buying $400 when you can get the Dorman equivalent for $100?
Only ones i've heard of giving issues are the TYC and Dorman fans. You can do like CrazyKid did,and adapt the factory motor into them though,but that won't fix the aftermarket cheap V6 fans if they have the vibrating blade. The stock e-fan isn't bad. For the majority of guys,it's perfectly adequate to use if you do the clutch fan delete,plus it's already on the trucks and doesn't cost you squat,Has anyone with a Mopar efan had one die? I can't say I've seen anyone talk about that on here or any of the FB groups....
The Dorman fans are a lot better about blade quality over the tyc. My blades are pretty balanced thankfully. The factory motor and the dorman motor have the exact same bolt pattern and size so they are a direct swapOnly ones i've heard of giving issues are the TYC and Dorman fans. You can do like CrazyKid did,and adapt the factory motor into them though,but that won't fix the aftermarket cheap V6 fans if they have the vibrating blade. The stock e-fan isn't bad. For the majority of guys,it's perfectly adequate to use if you do the clutch fan delete,plus it's already on the trucks and doesn't cost you squat,
Right that's my plan if and when my V6 efan craps out, swap over the motor from the factory AC fan.Only ones i've heard of giving issues are the TYC and Dorman fans. You can do like CrazyKid did,and adapt the factory motor into them though,but that won't fix the aftermarket cheap V6 fans if they have the vibrating blade. The stock e-fan isn't bad. For the majority of guys,it's perfectly adequate to use if you do the clutch fan delete,plus it's already on the trucks and doesn't cost you squat,
