Custom rear springs?
kg93
kg93
AZ
Looking back at your pics the control arm angle doesn't look to bad... can you snap a shot of just the arm angle?
If they don't look super steep, then the spohns will prob be just fine or just look into a shop making you some of your own arms using a Johnny joint on one end and a regular rubber urethane bushing on the other.
But I think relooking the spohns should be good.
here are the arms
y3mH8psFdvR-CO1-_kMNbwGp3iA7tB3MV3EmF5jYHs2rLeNnqBdGurSkfYzMiU1C3CgbQ8c6fht17i-pu4cX-v3gvRbGO32oTP99LRIRCbnYaabjPTp9y2LJ254_gpboGsKSuK5AmBYPCDRRoXrRt2RHANSS-jtZZykg5erMawfqx8
So im not sure if the jeep wedges would work. this is what our spring perch looks like... and there is no hole in the middle for a retainer. Would need to be drilled. Idk if the nub, idk what to call it, is long enough to still hold the spring with a wedge on it
y3mP1-oPXnZP15arPSsXPdosKDiTNtonXjmMpGRl9UBJ_RqJjtlQCPSOVqx4Hk-eWzG8Q2nUNmOgySlbe-k9Nhry15Fp_QWCzk_Owj81DcErNqL7GerflySVfGCbFbsaoLhGWzxHfaKZ3d7zkeoz1ueE8zFUqqvhldyRGL00JuvJvM
y3mM9pW4bFUityWy3NywU5LAA6E_FpAxj-_cDhyJHdXb8tzbGB18T0kTApV63NEKKR5vn3EdNdo4kytIfagT0i7zWVT7bZqlD0qac7NN1R9hV-_BG_M5xwc-dGG5oO78Sx2eXGFIaK_lSO2GH4WWvgeB4nGbrVYWIwoQ5e3ncV_oQ0
R/T_Fire
Pleasant Grove
The angle isnt as bad as i though they would be. Personally im not a fan of wedges or anything that puts another hinge point. Not really sure if correcting the spring mount angle would correct the arch in the spring. But my gut feeling says it would and its not alot of work or hard for a shop to do. Also a good source for HD susp parts for 4x4 stuff is ballisticfab.com. not sure if you have heard of them but if not worth poking around their site for ideas and whats available.
Sent from my SM-G920V using Tapatalk
kg93
kg93
AZ
ill have to check with my shop to see how much it would cost to replace them
Mauzz
Orca
