Cv angle(not much at all) with bils set at 2.1
_simm_ns
_simm_ns
Arlington, Texas
Where did you find these spacers? I've been looking for some.
Sent from my SM-G930W8 using Tapatalk
Which ones? Front or rear? Both on amazon but .5 fronts were hard to find. Unless you type it out right lol. I'll post both in a bit
Jim_Thurston
The .5 fronts
_simm_ns
_simm_ns
Arlington, Texas
Jim_Thurston
MotoFab Lifts DR-5 - 1/2" Front Leveling Lift Kit That Will Raise The Front Of Your Dodge Ram Pickup 1/2" https://www.amazon.com/dp/B017WNEEJ0/ref=cm_sw_r_cp_apa_yXaRzbY230ZC5
MotoFab Lifts DR-1.5R - 1.5" Rear Lift Kit That Will Lift The Rear Of Your Dodge Ram Pickup 1.5" https://www.amazon.com/dp/B00I50591C/ref=cm_sw_r_cp_apa_6XaRzb1HQRS1T
Thanks, does is actually give you 1/2" or more?
Bzubke1
Op???
Original post. I'm wondering if the angles on your truck are typical to what others see with the bilsteins set at 2.1 because that looks great.
_simm_ns
_simm_ns
Arlington, Texas
O OK yeah I have no idea I was checking things out down there and was surprised at how level it was
2k9ram
Here are mine @ 2.1
Solid State
2011 Bighorn
Here's mine @ 2.8
2k9ram
That's odd... is this normal for 2.1? That's about what mine looks like now with the added spacer
No Idea? Do mine look bad? It seems like every truck is different. When I have compared my measurements to others @ 2.1 it seems like my truck does sit higher than many. My front from the ground to the center of the wheel well is 40 1/4 on the passenger side & 40 1/8 on the driver side.
I'm uploading a couple pics that I took from behind the tire rather than the front.
_simm_ns
_simm_ns
Arlington, Texas
Are you sure you're at 2.1 and not 2.8???
2k9ram
It's crazy how differently these trucks respond to the bils
Isn't that the truth! But it's also crazy the difference in stance with factory configurations as well.
_simm_ns
_simm_ns
Arlington, Texas
So true. I wonder if it has to do with how many models they have.... ram offers a crap ton of different packages. And just about all of them are exist in every door, bed, and power train configurations....
6.7CumminsDrvr
The Dude abides………
Georgia
Mine looked darn near dead level like that @2.1.......I've got a pic around here somewhere
6.7CumminsDrvr
The Dude abides………
Georgia
Let's see it lol
Well, I can't seem to find a pic @ 2.1, my bad. I found a couple of pics from my 2012 at stock ride height and thought they looked to go up just a hair, and also found a current pic with the 4" lift/0.7" combo which look dead level..........
_simm_ns
_simm_ns
Arlington, Texas
Hmm. Interesting.
