mike2me
- Dec 2, 2012
- 28
- 2
- Location
- SE Wisconsin
- 1997
- 318 - 5.2L V8
I'm going to put a 5" lift on my 97 4x4 to fit the 35s I have, but this is my toy truck so I'm not about to drop a ton of money into a lift kit. My goal is to lift it for around $400 (springs/shocks/pitman arm (if req)/extended shackles/ professional alignment when done)
For the front I'm going to buy a set of springs and shocks and fab up my own extended control arms,track bar relocater bracket, either make my own sway bar drop bracket or buy extended sway links, and try to make the lift work with my pitman arm by bolting the steering linkage to the bottom side (its on the top now) but if that doesn't work I'm willing to purchase an extended pitman arm.
In the rear I'm making some extended shackles to drop the springs and avoiding blocks completely.
Does anyone here have experience lifting this truck because I'm looking for some insight before i get to work.
Also if anyone has the specifics for the fabrication that I'm going to do, it would be cool if someone could shoot out some numbers like the length the control arms should be for the 5" lift, or how far the track bar needs to be shifted from stock.
Regardless im going to get started on the project soon but any advice beforehand would be greatly appreciated.
