Dash turns off while driving. Then def needs service turns on
scubaseth
My Dash turned off then back on but my engine stayed on. Then def needs service turns on. My parking sensors also keep over sensing and go off.
I see alot of problems with dash lights staying on. But nothing about them turning off while driving and then back on.
2016 Laramie ecodiesel
Sent from my SM-N986U using Tapatalk
Administrator
sounds like a problem with a wiring harness. Especially check the ones going to the BCM which is about behind the brake pedal and there's a large one inside the frame rails on the driver's side around the front of the transmission
S
scubaseth
Thanks! I will look if the dealer can't find the problem. 4 days and nothing.
S
scubaseth
I wouldn't think that would be such a problem while the truck is started.
S
scubaseth
They said they found 2 bad wires on a wiring harness. They couldn't find why the dash went off. Could of been related to the def wires being bad.
Along with 2 bad rear parking sensors.
S
scubaseth
Update. Dash shut off again. They said after 2 weeks that it was my battery terminals. Hmm not a great feeling of it really being fixed.
