Dee Zee Tailgate Assist
Giorgio_Rampa
Vaudreuil
V6 3.6L
Does anyone know if you HAVE to remove this rubber?
I didn't install it yet, but if this rubber has to come off, I'll return the item.
Thanks!
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
I just installed this last night and took mine off per the instructions.
It stops the tail gate from rattling though (so I read), that's why I didn't want to remove it.
I'll install it tomorrow knowing I can keep that rubber piece there.
mullet6577
Memphis
2016 Sport
I pulled mine just because the instructions said to. I was actually going to see if it would go back on this afternoon but now that it seems like it does I'll just put it back on without needing to check anything myself.
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
I just installed it today, and it does press against that rubber piece. I didn't remove it but it makes sense why they mentioned to take it off.
Ramsteen23
MA
I removed it on my 2016 when I installed it and I never had any rattling...I held on to the piece just in case but never needed to put it back.
gofishn
Iowa
hemi 5.7L, 345 cu in
Remove it. Not removing may cause far more issues than removingit, prevents.
soem gusy worry about every little thing, evne the ones that will never ever happen.
If tailgates otu of alignement, then align it so it do es nto rattle. how much do you really think that peice of rubber is goign to do, or last, once that metal tailgate starts slamming around , o n it or against it?
if ya need it, add it back, later, high and out of the way.
Ole Buck
South Alabama
Damn, my ole southern ass read this and thought for a second that i was still in the shine from last weekend.
BWL
Embrace the skeptisism
BC Canada
Been in there 5 years with no issues
JohnBike
Buckley WA
I left it on my 2014 1500, but removed it after the first attempt to close the gate. The cylinder was pressed hard against the rubber pad. That pressure was just setting up the cylinder for a future leak.
As others have said, no rattles or squeaks with the pad removed.
