truckin151
Oh and yes you can adjust the throttles sensitivity
No TQ management user tools, the tune reduces it back real low though. Rev limiter can go up to 7000rpm, your WOT shift points though will only go to 6200rpm without it custom tuned. Shifts are firm and quick but not as firm or quick as the SC (add in a sonnax and you are golden though). If you go with a custom tune, you can reduce the TM and raise the line pressure for different shifts also set the TQ converter lock up settings, raise the WOT shift points so you can have a 6600rpm shift in DRIVE instead of manual shifting. and that just cracks the surface of it. This is where I am heading with mine
