From the sound of it, you'll need custom tuning for the trans tuning. It will not be available to be adjusted without cmr
Bumping this thread because I literally have the i2/PCM combo in my cart at Moes to order right now. The only thing holding me back is the trans tuning. I contacted Hemifever on facebook asking about the trans tuning on the i2, waiting on a response.
...they have confirmed everything works on the 2015-2016's
I had the Trinity on this truck, but the beta trans tuning is only currently available on the i2.
I had to remove the trinity, update the i2, load a TCM file onto the i2, and then plug it in to start loading a tune file onto the truck.
First it reads the stock PCM file and then loads the PCM tune. Then it reads the stock TCM file, and then loads the TCM tune.
From there, I had to send both the PCM and TCM backup files to Hemifever, and I'm now waiting for him to send the revised custom PCM and TCM files back to me. (Diablo had some mistakes in the rev limiter tables, so we are working with Diablo to get those corrected before loading the custom file onto the truck.)
Once Sean sends the custom tune files, I will then need to save both the PCM and TCM files onto the tuner, and then load them onto the truck.
Do you have the Pedal Commander on this truck? If so, what is your plan of attack regarding both the tune and PC? Thank you.
