Tim Denning
Can someone tell me if there is a visible difference in size between the 22 and 30 gallon tanks?
I believe that my tank was replaced because there are 2x4s under the tank between the straps and the tank. That makes me think the tank used to be larger and was replaced with a smaller one.
My issue is that the tank is leaking around the fuel sending unit and if I have to get a new sending unit, I need to know which size to get.
I did fill the tank up and it took about 20 gallons but I don't know how much was in the tank to start with (the truck is new to me and the gas gauge is not working correctly). Unfortunately, I didn't know about the leak until after I filled it up.
