krb686
- Dec 30, 2014
- 53
- 4
- 2014
- Hemi 5.7l
The controls for the audio on the 8.4 bezel have no connectors on our lower trim trucks. So there is no control for the volume unless you have the steering wheel controls. The oemautoparts bezel has a volume control on it. I don't yet know how it interfaces with the wiring we have in our truck to control the volume.
The climate control on the 8.4 bezel has no connector on our trucks. So there is no way to control the HVAC with the bezel and since there is nothing like a steering wheel HVAC control you have to use the 5.0 bezel with the 8.4 radio in order to still have climate controls.
Over on the Z there is a person trying to get it all figured out so that we can use the 8.4 bezels with our trucks. Once they get it figured out I'm going to go with a factory 8.4 bezel. In the mean time I'm using my 5.0 bezel until they release one of the oemauto bezels with a knob instead of a switch for volume control then I will use it.
According to the mirror thread of this one over on Z (http://www.ramforumz.com/showthread.php?t=180908), the audio was determined to be connected simply through the CAN bus, stated on page 20 by duneflyer.
Now just to figure out how to solve this HVAC issue. If the HVAC controls on the 8.4 bezel simply connect to the CAN bus, then perhaps the lower trim 3.0/5.0 trucks do not have the correct software to be able to interpret those CAN bus commands, even if wired correctly.
