- Dec 1, 2013
- 12,803
- 12,501
- Location
- Bristol , Tn.
- 2014 4X4 QC Express 6 speed auto 355 differentials
- 5.7 Hemi
Lol , maybe I should've been more clear .HARNESS? I was told I just needed the buttons? Is there also a clock spring?
I'll try now
Yes there is a clockspring , it's part of your truck already and will be a non factor for you so long as jack the front end up , in order to install the audio control " buttons " you must remove the steering wheel, in order to remove the steering wheel you must remove the air bag , in order to remove the airbag in the center of the steering wheel you must release 3 ea clips , since you gotta turn the wheel approximately 60° left & right , I found it benificial to jack up the front of the truck Untill light pressure to the ground.
The truck will not be under power because you MUST have the neg terminal off the battery ( so no power steering .
Some have had trouble getting the clockspring out of alignment by turning the wheel .
Now when I say Harness the "buttons" for the audio control have wires , this is the harness I was referring to .
Now that this is as clear as mud , I suggest watching the video on removal of the sterring wheel and installing the audio controls . It's actually very simple , you will see when you watch the video
I'll look for the video and post it here , if I can find it ....
Ha , it's actually post #1 here .
https://tapatalk.com/shareLink?url=...&share_tid=54449&share_fid=17770&share_type=t
DIY: 2013-2014 OEM Steering Wheel Audio Control Install
A link to the audio controls kit ,
http://www.allmoparparts.com/mobile/1500-steering-wheel-audio-control-upgrade-p-5793.html
Another video for air bag removal ( this guy is a Rockstar ! ) this is exactly how I did it , except I had the front jacked up a bit to make the wheel easier to turn . The tool he's using is a cotter pin removal tool .
Lots of guys use a puller for the wheel removal , I gave mine a good jerk , then applied contact pressure with one hand and smacked it pretty good with the other and it pope right off .
Hope this helps !
