DIY WATER PUMP INSTRUCTIONS
Shoofly
Catoosa, OK
Not one post about water pump change says a darn thing thing about how to do it. Just blabbing about taking it to a mechanic and stupid stuff. Can anyone tell me how to do the job?
Can't get nut loose on fan.
chopperman1
2018 Rebel
5.7L HEMI
Tighten the belt with a breaker bar pushing in the opposite way the tensioner moves. Open end 36mm on the clutch/fan nut and give it a couple good whacks with a mini sledge. May need a little heat to break it. I prefer induction over torch.
chri5k
USA
Diesel
Search youtube. Plenty of videos on how to R&R Hemi water pumps. A video is worth 10,000 words.
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
Hold the pully with a pin spanner wrench.They are pretty tight.I've used a air hammer to break the stubborn ones loose a few times.Good luck.
Runaround
Silsbee
It does take a good fitting wrench and several wacks on the wrench with a decent sized hammer. The threads are opposite of what you would expect. It also helps to leave the belt on until you get this nut broken loose. Upon reinstalling, thread that big nut on as far as you can by hand and then wack the wrench once or twice to get it snug. It only has to be snug. It will tighten itself snugger.
Daw14
Left hand threads.
