Egged class V
sandawilliams
Pueblo West, Co.
6.4 hemi
Just inspected my 2014 2500 and found the class V receiver is egged out. I cant even get the class IV adapter out now. I purchased the pin from the dealer were I bought the truck. I only pull may TT that is under 8000 Lbs. loaded. (yes I weighed it) Anybody else having this problem?
drittal
E. Montana
The pin hole?
Sent from my SM-N900V using Tapatalk
drittal
E. Montana
Are you using wdh with the adaptor?
drittal
E. Montana
I know the adaptor pin hole is elongated vertically from the factory. Is yours being elongated vertically?
sandawilliams
sandawilliams
Pueblo West, Co.
6.4 hemi
I cant get the adaptor out of the class V as it is the class V that is elongated vertically.
drittal
E. Montana
I wonder if the extra slack by running the adaptor with the WDH and normal use places a lot of stress on the pin without the adaptor helping since it's pin hole is elongated similarly.
I've read that we shouldn't be using adaptors with WDH, but many refute it.
Hopefully yours isn't related, but that would definitely worry me.
Do you ever feel like there is excessive motion, jerking, or porpoising when you tow?
PippinAin'tEasy
Sidebar: are the IV adapters actually adapters? Held mine up to a 1500 and it looks for all the world like an unwelded receiver. Re OP's post can you see the bow out in the steel or is the adapter just stuck? Mine likes to grip inside more often than not. It's usually the paint that likes to hold after I've been running the WDH. Couple of mallet taps pops it free. Good luck with the conundrum.
"Oh, sweet debt. Thy name is Truck."
Jackfate
I have been told you will bend pins using the adapter . So this would go along with your problem. I'll see if this happens to me
PippinAin'tEasy
Has anyone ever seen a bent pin, even under extreme (conventional towing) conditions? Ain't saying I've towed a lot of stuff but I have towed a bunch of stuff and never have I beheld such an event.
Sent from my SAMSUNG-SGH-I467 using Tapatalk
sandawilliams
sandawilliams
Pueblo West, Co.
6.4 hemi
I went through the owners manual and looked online and can find nothing about not using the WDH with the adaptor. I hope I wouldn't need to buy a class V hitch assembly to tow my camper.
Jackfate
I'll let you see it after I cut it in two or three pcs in a couple wks so I can remove it ; ) .
Sorry I spend too much time on the towing webs
Check my post going from class 4 to 5
drittal
E. Montana
I've read about a vent pin at RV.net, never seen one.
JustinRam1500
