Pistol
I just installed an Eibach Pro Lift kit and a set of Zone UCAs on my 2014 Ram 4x4 and wanted to pass on some info and tips. I was running Bilstien 5100s on the front and rear with the front set at 2.1. The apex of the front fender wells were sitting at 38 9/16" and the rear at 39". After installing the Eibach kit with the front struts set at 2.25 and allowing everything to settle the front fender well is 39 7/8" and the rear is at 40". I'm hoping the front will settle a little more.
If you are looking to go with this kit and plan to do it yourself and renting spring compressors you will need 2 sets. A single set of spring compressors will not compress the Eibach springs. I initially rented the PowerBuilt Strut Coil Compressor and it worked great for the stock springs but when I tried it on the Eibachs... I bent the main shaft and the arms that compress the coils which caused the spring to launch and put a 3" hole in the ceiling of my garage.
I then got a set of spring compressors and realized that wasn't going to work either. Use 2 sets of outer type spring compresses for the Eibach Springs.
Also, be ready to get an alignment. My wheels were severely toed in.
Here are the before and after pics. The front settled 1/2" after the pictures were taken.
