Engine Problem Flashing CEL p0300 code
blk05hemi
Bovina, TX
Cummins 6.7
Hey guys got a problem that has been bothering me as i have to drive my truck everyday. I started getting a flashing CEL it comes up as p0300 multiple cylinder misfire woohoo! Plugs and wires have been changed runs 91 fuel throttle body is clean.
The truck runs pretty damn ****** like pulling hard running rough at stop or idle mostly at around 1500 rpm it runs the worst and after 2000 it clears up.
another thing is im getting a squeaking noise when backing up only
Any ideas guys id really love the help!
bigbadram1500
Springfield, IL
I had a similar problem and ended up with the codes of cylinder 8 misfire and a crankshaft position sensor. It would kick and buck and start misfiring and I ended up on the side of the road with a flashing CEL and the whole truck shaking from it misfiring so bad. Scared the crap out of me. Ended up limping it to the dealer and got the sensor replaced.
quietpeen
2021 TRX
Hellcat
when backing up where does it sound like the squeaking is coming from?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Mine misfired pretty bad for a whole day, almost took it in o get looked at but ended up going through the engine bay, found a loose ground that was causing the problem.
HemiBabe
DFW
Hope you get it figured out
blk05hemi
blk05hemi
Bovina, TX
Cummins 6.7
Dropped the truck off at the stealership hopefully they will take care of whatever is wrong..
blk05hemi
blk05hemi
Bovina, TX
Cummins 6.7
Stealership tried to steal from me so told em to shove it lol. They wanted $500 dollars to replace all four o2 sensors... Did it for about $120 and its runnin good
BlackedOutHemi
DFW, Texas
2012 & 2012
They tend to do that. Haha. Glad you got it worked out.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The upstream ones would have caused it, the down streams shouldnt have though. Glad it was nothing major bud. Did any of them look fouled out bad?
blk05hemi
blk05hemi
Bovina, TX
Cummins 6.7
Yeah they looked pretty bad lol. It was the passenger side upstream that was causing all the mayhem but i just replaced all four so i could get that damn engine light off finally.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Hopefuly they wont to bad to get out of the headers.
avgjoetx
Austin, TX
5.7L
Had the same code on my 2008 5.7 and it started dying on me. In Dec 2017 it now has 65K miles. So it is lightly driven and garaged. It started off dying once a month. Then it would not stay running for more than a minute. I suspect the code was a byproduct of the engine dying. No other codes given. So I started the "sensor hunt" Replaced the MAP, 1st O2, intake temp, crankshaft sensor, and all the plugs (needed that anyway). One of the last two things seems to have solved it. 1. replaced the cam sensor. 2. loosened and tightened both battery ground wires. I cannot say for sure which one solved it but now it seems to be running fine. I will let you know if it does not pass the long term test. Next step was throttle body, I hope I can return that one but will hang on to it for a while.
deathmonkey2020
