Engine rattle on start up
ram5.7hemi
N/A
N/A
I just got a new truck 2014 ram with 12000 miles...
Today I started it and heard a very short rattle and then it ran normal... I turned it off and on a couple times and it didn't do it...
Anyone ever heard of this or had this happen?
It definitely sounded different then usual but only did it once... I might just be a little paranoid my old truck had a lot of issues and I had to have it repaired a lot...
Kotta390
I have been told that this is normal on cold starts, normally if the truck has been sitting for awhile over a couple days maybe. Mine does that too but if you start it everyday or so, you will never hear it.
R
ram5.7hemi
N/A
N/A
Well I've had it less than a week so far and have started it at least 2 times a day sometimes more if I did running around and today it didn't do that this morning but did in the afternoon but only once
14hemiexpress
6.4l
Mine does it quite often if been sitting for a while or like on a slope, I've never liked the sound but doesn't seem to hurt anything I don't get any metal shaving when I change my oil so as long as it doesn't do it when warmed up and always goes away fast I wouldn't worry about it.
JasonK94Z
Moore, OK
Put a different brand of oil filter on it next oil change. Something to do with the anti drain back valve in the filter. I use Wix. Royal Purple is a good one too.
My truck did it after sitting for awhile, but only when it had a Mopar filter installed. That was cause I was getting free oil changes.
Ratket
Arizona-
^ what he said.. mine did this with a k&n oil filter once when I was parked on a slope.. switched to a royal purple and hasn't done it since.
CapeRR
Nova Scotia
Mine has done this a couple of times in the the almost two years I've had it. Some say occasional lifter bleed down or like mentioned it could be the filter in your case. I had a Wix filter on it the times it did it but the last oil change I put a Mopar on and haven't heard it yet.
OasisNinjaBat
