Engine shut off
ramon222003
Laredo, TX
I have a problem with my truck shutting off when coming to a stop whether it be at a traffic light or stop sign. As I start to slow down the rpm's go real low and then the truck completely shuts off. It doesn't always happen but when it does it sucks because I have to put it in park and start it up again then I can take off. Any thoughts on what it could be? What can I do? Any help or suggestions will be appreciated. Thanks.
MADDOG
Out Exploring Arizona
Is your check engine light on? If so, get the code read at a local auto parts store.
If not, it could be a fuel pressure problem, either the regulator or the fuel pump.
It could also be a throttle position sensor issue but normally those throw a code.
whetrick1
I'd say more than likely the throttle position sensor
RamCares
n/a
n/a
Hi ramon222003,
Sorry to hear about this! If you decide to visit your local dealership I'd be happy to follow up with them for you if needed. Just PM our page and let me know.
Andrea
Ram Social Care Specialist
